I have a Monport K40 plus, haven´t used it for about a month or two. I wanted to use it again this morning and I found a small nest inside. Strange because the biggest hole in the frame is about 2 cm but it must have been a small mouse I guess.
Found the nest and it was made with small pieces of wire as well. Most wires are the ones to the steppenmotors. Does someone have some info of the connections so I can safely replace the wires?
The steppenmotors I can figure it our probably but also the safety switche wires are cut off.
