xTool D1 and F1 hardware:
Lightburn is trying to connect to com ports 1, 2 & 3, but my surface has 2 ports which are 4 & 5.
What is the work around for this issue? (if there is one)
My surface will not install the ch341ser.inf (tried many times)
1 - When connecting to Lightburn, it only shows 3 ports 1,2, 3
2 - When I connected my USB cable to my Surface, I can see what ports are being used. Ports 4 & 5.
3 - No, I does not create a port, it error out
Where does it error out? How are you determining that? A screenshot again would be helpful. But bottom line, if you’re not able to get a port defined for the laser LightBurn or any other control program will never work. First order of business is to work out how to get a serial port setup for the laser.
Are you deliberately avoiding answering the other questions? Please be direct if there’s a reason for that so that I can understand what to do with that information.
As for the Device Manager screenshot, the USB Serial Device on COM4, that seems like it could be associated to the laser but let’s try to confirm that. Try turning off your laser, then refresh Device Manager. Does that port go away? And is it recreated if you turn the laser back on?
My ports are 4 & 5, as I’ve said 2x’s.
It doesn’t matter how many times plugin or unplug both my D1, F1 or my printers. Does this answer your Question?
You haven’t addressed specific questions. I’m asking those questions to better understand the situation.
The information you’re providing is not sufficient to move the troubleshooting forward. If you’re interested in exploring then will need that specific information. If you’re not interested then please just state so.
Here was my followup to this point.
It’s not clear to me what you’re referring to here. You stating it is not making it clearer to me. By including a screenshot I can understand the context for which you’re stating it. It will likely convey information that your summary is not.
The other questions I’d like answered:
I want to understand what you’re seeing here as well for the same reason.
