Microsoft Pro Lightburn Setup
Hello all,
I am looking for some help setting up my Lightburn on my new Microsoft Surface. The new surface only comes with USB-C ports. I’ve tried using a USB-C to USB-A adapter and downloading the CH340 driver with no luck. I bought an adapter for USB-C to ethernet. I put the IPV4 address in and changed the last digit, also with no luck. I tried to see if I could change the settings in the device manager but it did not work. Does anybody have any advice on what to try?
Machine: OMTECH Pro 2440 with Ruida Controller
Device name DESKTOP-ABACLDM
Processor Snapdragon(R) X 12-core X1E80100 @ 3.40 GHz 3.42 GHz
Installed RAM 16.0 GB (15.4 GB usable)
Device ID D1429144-E916-4287-8253-3852A8E1B96F
Product ID 00356-06302-81026-AAOEM
System type 64-bit operating system, ARM-based processor
Pen and touch Pen and touch support with 10 touch points
Somebody may correct me here, but I think Lightburn will not run on ARM processors. That said, some have managed to get it running on Raspberry Pi 5 computers.
If your laptop has a local lan connection you can use Ethernet, much more dependable and once setup, should work. I’ve been running it for over 5 years.
Then you don’t have to mess with usb drivers and other headaches caused by usb issues.
I know they talked about an ARM version, but I don’t know the status. I assume Lightburn runs on that platform?
