Millenium Machines Milo 1.5 (or other RepRap Firmware based machines)?
Hi all.
I’d be instantly banned for expressing my opinion of F360. A friend suggested I look at MillMage today, and I online know one of your lovely staff, as it turns out MillMage is part of Lightburn!
Has anyone got MillMage running a Milo? Millennium Machines · GitHub
Fusion is driving me nuts. I only need the basic path generations, the specific part I want to machine is essentially about as simple as a milled part can be, and it’s pine! So I’m hopeful that even a basic 2.5D solution would do the job.
Also, the Milo uses a captive web portal with the worst UX I’ve ever used on a modern machine - touchscreen, but 6 buttons that loop badly on a small screen, and missing a click slightly will move your tool (say) 50mm instead of 0.05mm! Glad to see MillMage has that problem solved from the outset!
Download a Release Candidate and see if you can get it working. However, I think MillMage is primarily based on GRBL controllers for now. I found one reference to the Milo in the Forum, but there was no indication it was acttualy running.
If your machine can import GCode files you can save to GC and run on your machine.
