MillMage 0.8.00 RC-10 Release Candidate
The tenth Release Candidate of our new software for CNC users — MillMage — is available for download now!
Continuing the development of MillMage, this release candidate update includes many bug fixes and tweaks.
MillMage-v0.8.00-RC-10 - Change Log
Changes Since MillMage-v0.8.00-RC-9
Existing Feature Updates
  • Added URL and Notes to Tool Spec and allow click on … button to open url in browser.
  • Added guided setup steps for Custom GCode Options that require user configured GCode blocks.
  • Apply Tool to multiple Operations from the right click menu in the Operations panel.
  • Allow larger stepover with raster ops (#1379)
  • Automatic TabBuilder fixed to prevent having first and last tabs closer than the minimum requested distance. (#1385)
  • TabWizard fixed to prevent having first and last tabs closer than the minimum requested distance.
  • Created a Face operation that does not allow tool direction changes within the material of the cut area.
  • Allow user to specify the Face clearance as a percentage of Tool Radius.
Bug Fixes
  • Invalid DXF color indices could crash on import (#1376)
  • Rest pocket with no resulting clearance area could crash (#1382)
  • Trim would fail if snipping a shape scaled to zero in X or Y (#1383)
  • Fixed issue causing custom Alarm and Error codes from replicating when switching GCode flavor in the Device Settings dialog.
  • Fix trochoidal circle rotation and smoothness problems (#1375)
  • Fixed bug in Beginner Project setup that could result in the actual Project Origin being different to the Project Origin selected in the wizard.
  • Added a small distance tolerance to the pocket lift check (#1387)
New Features
  • Operations Export now uses device Save File Extension
