MillMage 0.8.00 RC-13 Release Candidate
The thirteenth Release Candidate of our new software for CNC users — MillMage — is available for download now!
Index of /MillMage/RC/MillMage-v0.8.00-RC-13/
Continuing the development of MillMage, this release candidate update includes bug fixes, tweaks, and feature additions.
MillMage-v0.8.00-RC-13 - Change Log
Changes Since MillMage-v0.8.00-RC-12
Bug Fixes
  • Fixed ‘out of bounds’ misfire on auto-used op shapes (#1451)
  • Curved single-prim shapes with linear ramp sometimes messed up flute op (#1450)
  • DEV-2309 Quick Nest acting up if Device Origin is top left. (#1443)
  • Fixed invalid KillTimer condition warning.
  • Allow overrides to be set BEFORE starting the job for GRBL.
  • Fixed fatal crash when applying a radius to a line segment.
  • Fixed simulation display not being centered on the panel
  • Catch illegal memory access to prevent crash, and show properties correctly for multi shape.
  • Can’t test layer index before layers are assigned (#1457)
  • Handle offset and raster pocket lift differently (#1458)
  • Fixed issue that allowed project and library tools to have the same ID even though the tool properties do not match.
  • Copying a tool would not update the tool properties in the UI before switching into edit mode.
  • Tool library management button states are now correctly set when a project tool or the project category is selected.
  • Fixed issue with some numeric input boxes not displaying unit values when units are set to metric.
  • Fixed issue with Tool Library visualization not showing the full value of any fractional radius dimensions.
  • Fixing punctuation in dialog messages. (#1468)
  • Fix tool position displayed and the move machine to … commands for All 5 possible workpiece origins.
  • Save and load the Layer properties with a project or template (#1461)
  • Fixed the Tab wizard when using tab count, building one less tab than expected. (#1459)
  • Correct device origin reporting in New Device Wizard summary (#1474)
  • Fix for incorrect WeCreate disconnect message (#1478)
  • Fixing the need to turn off and on again the Show All toggle in the Console for gcode if a connection is reset or device changed.
  • Fixing a continuous Z jog bug.
  • Fix the order of conjunction for small islands. (#1482)
  • DEV-2403 Font Dropdown Box displays font headers (#1486)
  • DEV-2403 Font Dropdown Box displays “Favorites” as a selected font
Existing Feature Updates
  • Scissor Tool with shift-click should move entire shape to current layer just like trimming a section does. (#1445)
  • When user clicks the STOP button, ensure that the M2 command is sent for GRBL devices to reset the overrides.
  • Allow round-over bits to be used for pocket (#1453)
  • Limit outgoing TCP queue size to 8K
  • Clear ToolState on device disconnect (#1448)
  • Changed text in 2 places to License Management to be consistent (#1462)
User Interface Updates
  • Added “Workspace DPI Scaling” display setting. This allows higher resolution drawing / previews to be switched off to improve line visibility on very high resolution display (eg. Apple Retina), or to improve performance on low powered devices.
  • Changed console and custom GCode settings font from “Courier” to “Consolas” if available on Windows devices.
Miscellaneous
  • Add the ability to skip the first tool change macro (#1480)
Code Refactors
  • The Allow G53 toggle was only affecting position queries. This now prevents sending it in any circumstance.
New Features
  • Fluting pattern visualization preview in CNC operations dialog
Can you provide some detail on this? I accomplished this with some conditional gcode but if there is a checkbox or something, that would be great.
No rush. It’s the holiday. I appreciate all of your work on this. It’s looking great.
Just wanted to followup on this. Thanks.
@jeyeager, so sorry to have not gotten back to you sooner.
For most users, it’s extremely likely that the first tool change in the file is something they already did while setting up the job. So we let you skip the first TLO probe if you desire.
When one is prompted to insert Tool X the very first time for the job, the message dialog will have Continue, Abort, and Skip. Every other time it’s just Continue and Abort.
