MillMage 0.8.00 RC-14 Release Candidate
The fourteenth Release Candidate of our new software for CNC users — MillMage — is available for download now!
Index of /MillMage/RC/MillMage-v0.8.00-RC-14/
Continuing the development of MillMage, this release candidate update includes bug fixes, tweaks, and feature additions.
MillMage-v0.8.00-RC-14 - Change Log
Changes Since MillMage-v0.8.00-RC-13
Bug Fixes
  • Properly saving dwell time and retract rate on peck drill operations.
  • Added ALL button for picking axes. Fixed bad spin box increments for Velocity. Save all probe changes immediately to prevent loss if user clicks back button to adjust position. Get the tool diameter for probing from the first enabled operation instead of using zero.
  • Fix program stall on update for FilletTool
  • Tool library stepover and pass depth unit conversion bug
  • Unsaved changes indictor in window title fixed for change of device.
  • Got Jogging working when in Operations Mode.
  • Jog distance and speed were not being restored properly on program start due to unintended events.
  • Fixed a shutdown crash from event filter
  • Unit conversion fixes for stepover, pass depth
  • Fixed non-uniform scaled icon import alpha artifacts
  • Radius calc fix on rounded VBits and allow steeper tool path arrow angles
  • Close Project Setup dialog crashes on mac when edit window intialized fix
  • Limit speed/power overrides to 10-200%
  • Click to remove fillet didn’t always work
User Interface Updates
  • Added startup checks for common issues that cause ui elements to grow too large for the screen.
  • Added prompt to automatically restart when settings are changed that require an application restart to apply.
  • Tool Library notes field now correctly strips formatting from pasted text.
  • Macro Edit text input now correctly strips formatting from pasted text.
Language Updates
  • Add Finnish translation
New Features
  • Fluting Preview Dialog Final Touch Ups
Existing Feature Updates
  • Added preview button to Operations view
  • Allow multiple ops to be deleted at once
Miscellaneous
  • Some default tools still used 100RPM
