MillMage 0.8.00 RC-4 Release Candidate
The fourth Release Candidate of our new software for CNC users — MillMage — is available for download now!
Another major step in the development of MillMage, this release candidate update includes many bug fixes and tweaks.
MillMage-v0.8.00-RC-4 - Change Log
Changes Since MillMage-v0.8.00-RC-3
Bug Fixes
  • Removing special MillMage tool probe routine placeholder in the gcode output if machines can’t be controlled.
  • Correcting the base URL lookup for MillMage.
  • Remove ‘Project Wizard’ from ‘CNC Tools’ menu bar (#1006)
  • Fixed bug that allowed a job or framing to start when there are no operations to output.
  • Fixed bug that allowed a job or framing to start when shapes overlap stock bounds and the user chooses “No” when asked whether they wish to continue.
  • Fixed font scaling bug that can occur while adjusting the font size slider, located in the Display tab of the settings window.
  • Make fonts saved in 2.0 compatible with older versions (#1026)
  • Setting TLO to 0 if doing a block Z probe.
  • Add warning in case of unsupported configuration with split jobs.
  • Fix Show Last Position
  • Fix move Dock window being disabled after adding first device, requiring a restart to enable it. (#1028)
  • Fix the GoTo button functionality on gcode devices.
  • Prevent crash if the tool head is too big to fit into a rest pocket or other geometry, ignore operation instead.
New Features
  • Adding Masso as a Gcode flavor
