MillMage 0.9.00 Early Access – RC-7
The MillMage 0.9 Early Access - RC-7 release is available here. We are expecting this to be the final Release Candidate for our MillMage 0.9 version. With this release, we provide a critical bug fix identified below.
Change Log for MillMage-v0.9.00-RC-7
Changes Since MillMage-v0.9.00-RC-6
Bug Fixes
  • Tool offset blocks were not showing in GCode block editor
  • Update default Z search distance to 30mm instead of 100mm for new probe definition
  • Fixed incorrect 3D model rotation when switching between rotating with mouse and manually setting rotation fields.
  • Fixed tab order of controls in 3D import dialog.
  • Verifying if the work offset probe didn’t throw an error before starting TLO wizard automatically.
  • Connection buffers could block in rare circumstances on flakey grblHAL controllers
  • Prevent Hang when generating Relief cut, ensure progress dialog can cancel.
User Interface Updates
  • Changed style of buttons in 3D import and depth map settings dialog to better show when a button has focus.
New Features
  • Add Cancel button during probe moves.
just reading whats in 0.9.00 updatebefore downloading it
Stand up and spin 3 times then sit down to enable chair monitor calibration
how many times should this be preformed a day ? :laughing:
Fixed error with drill tip measurement- was tip not included ? last lot shelf pin holes i drilled were deeper than usual , i have a saved operation for my shelf pin holes
ZigZag ramp didn’t work for vcarve with start depth != 0 , glad i wasn’t imagining that it was plunging at times :slight_smile:
