MillMage 0.9.00 RC-3 Release Candidate
Version three of our MillMage 0.9 Early Access release is available now. We’ve got a handful of bug fixes in this one — please give it a try and let us know if you find any more bugs that need squashing!
Just as with LightBurn RCs, you can install MillMage RCs side-by-side with the current official release. That means if you encounter any workflow-breaking bugs in the RC, you can quickly switch back to the official release to keep working.
If you are currently using MillMage with a Core license, head to Help → License Management and click the Trial Pro button to get access to all Pro features for two weeks. We will extend Pro trials for our existing Core users for the duration of the 0.9 RC period.
Changes Since MillMage-v0.9.00-RC-2
User Interface Updates
  • Changed layout of probe settings dialog from portrait to landscape so it will fit correctly on smaller displays.
Bug Fixes
  • Initial 3D relief plunge with Z-bottom bug
  • For all cut types warn in the GUI if startDepth is below the stock depth. For Texturing warn in GUI and if generated cut is below the stock depth.
  • Fixed inability to enter start or final depth percentage above 12% when units in inches
  • Fixed Sync Views toggle to save state
  • Fixed issue where framing could use the wrong origin offset
  • Custom GCode was not using custom header when framing
  • Duet / RRF HTTP “You are currently streaming to your device” on shutdown when unconnected
  • Removing spiral entry type for 3D roughing passes
  • Fixed RestoreDefaultLayout to work in Qt 6.11
