Hi Folks I have a 6090 China CNC driven with a Mk3/4 Planet-CNC Board
I need to change the board for something compatible.
Any Recommendations ?
Something reasonabley priced
Take a look at this
I have the jackpot 1 which works sweet as with MM
i like the Pibot 4.96 pro board, it uses FluidNC to for setup and very solid board, i use it with MM WIFI connection but it also supports USB and very good documentation. PIBot V4.96 Pro Controller :Start [PiBot Wiki] FluidNC Grbl CNC Laser Electronics
Thanks for the tip These have intricated drivers, I have 4 DM864I stepper drivers with Nema 57 Motors X,Y,Z & A with 48V individual power supply’s, one for each stepper motor this has reduced any power problems with the CNC. These are about the right price range but are from the US maybe something a little more universal from UK or Europe
the Jackpot 1 would work , but they are out of stock hence why i sent the link to the jackpot 3
theses boards are used world wide , im down in NZ and have the jackpot 1
I know there are lots from uk europe on the forum and use all sorts of steppers/drivers etc with the jackpot , check out the V1 forum
you can buy them in the UK
Jackpot CNC Controller FluidNC V1 Engineering MPCNC LowRider CNC but out of stock als0
If you are using external drivers, I would look at the 6x or Doberman boards from Bart Dring. He’s one of the primary FluidNC devs.
Doberman CNC Controller | Wiki.js
6x CNC Controller | Wiki.js
I don’t know what signal voltage your external drivers need.
