Minha gravadora laser: Alarme 2 (My laser engraver: Alarm 2 )
Tenho uma gravadora laser que montei com um laser de 15w, usando GRBL 1.1h.
Com dois eixos e com homing habilitado.
Tenho um problema que acontecendo quando coloco a posição absoluta.
I have a laser engraver that I built with a 15w laser, using GRBL 1.1h.
With two axes and homing enabled.
I have a problem that happens when I put the absolute position.
Alarme 2
Alarm 2
Mas no GRBL está habilitado $130 e $131(365 x 315).
Na configurações de dispositivo está com as mesmas medidas.
Quando coloco a imagem fora do ponto de origem ele da esse alarme 2 direto.
Já olhei tudo que imaginava e nada!
Vcs tem uma ideia, do que possa estar errado mas configurações?
Essas imagens, são das minhas configurações…
But in GRBL it is enabled $130 and $131(365 x 315).
In device settings it has the same measurements.
When I place the image outside the point of origin it gives this alarm 2 directly.
I’ve looked at everything I imagined and nothing!
Do you guys have an idea, what could be wrong but settings?
These images are from my settings…
Error 9 and Alarm 2 have different causes.
Error 9 says that the engraver is in a locked state. LightBurn has unlocked it for you. There was likely a previous Alarm.
ALARM 2 says that you tried to send the laser out of the allowed space.
This can be caused by homing incorrectly or physically moving the laser head when it is connected to LightBurn.
In the Console window in LightBurn Request the following reports:
$i
Pressing Enter after each one. If the first report tells us the position information related to ALARM 2. The second report tells us more about your laser.
Please copy both those reports into a reply here.
Next, in the Console window type:
$RST=#
and press enter.
This command erases G54-G59 WCS offsets along with G28/30 positions stored in EEPROM.
Finally, enter the following Command in the Console window.
$H
and press enter.
This should allow the laser to home.
Please use a screen capture tool:
Copy and paste for text is also helpful because it’s easy to put into a translator.
These may be worth review:
If the laser does not home we will increase the pull-off distance in $27=10
and set $130=355, $131=305 and retest.
[G54:-370.000,-330.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
$i
[VER:1.1h.20190830:]
[OPT:V,15,128]
Target buffer size found
ok
Eu consegui tirar esse erro (alarm02)
Usando um comando
G10 l2 P1 X-370 Y-330
Agora não dá mais alarm02 e consigo colocar a arte em qualquer lugar na mesa.
No
Agora tem um outro problema!
Coloco para fazer a gravação, depois de um tempo gravando a máquina para e o programa continua rodando e não dá nenhum tipo de alarme ou erro.
Já cheguei a tirar o cabo USB e o programa continua rodando.
Agora usando o laserGRBL, funciona normalmente.
Cheguei a trocar o cabo USB e coloquei um de boa qualidade e nada.
Tem algumas vezes que está quase terminando ele trava.
Outras vezes quase na metade trava TB.
Eu estou usando um notebook hp 6530b 32bits
I managed to get this error out (alarm02)
using a command
Now it no longer gives alarm02 and I can place the art anywhere on the table.
At the
Now there’s another problem!
I put it to record, after a while recording the machine stops and the program continues running and does not give any type of alarm or error.
I have already removed the USB cable and the program continues to run.
Now using the laserGRBL, it works normally.
I even changed the USB cable and put a good quality one and nothing.
There are times when it is almost finished and it crashes.
Other times almost halfway hangs TB.
I am using a notebook hp 6530b 32bit
With your project ready to begin, before the ‘Start’ and the Error message, Click File, select Save GCode. This will save the file that the engraver would be reading. The reason for the error should be there and visible.
If you’re willing to post it here, I believe you can upload the file in a reply as is. If the forum rules do not allow the filetype, simply change the filetype to .txt or add .txt on the end of he filename.
aqui esta o arquivo.
depois que baixar o arquivo.
Apague o .txt e coloca .rar;
porque e um arquivo compaquitado.
o arquivo .txt esta dentro dele.
o arquivo e muito grande e tive que fazer isso
here is the file.
after downloading the file.
Delete the .txt and place the .rar;
because it is a compressed file.
the .txt file is inside it.
the file is too big and I had to do this
homem de ferro (2).txt (760.7 KB)
