Minimum Power setting on one line of test card
Greetings All,
First, I’d like to wish you all a healthy and prosperous 2024!
Ok, I have a downloaded engraving test card where only one line, for some reason, has the minimum power setting greyed out and cannot be set. Every other line has it set to 20% and looks fine. 20% is visible in the settings but will not enable. The line graphic in “Preview” screen is very dark since the max power is set at 100%.
Is there a fix for this?
And “YES” I am a newbie.
Thank you in advance.
On g-code machines only grayscale images will allow for min power to be used. All other operations and modes will not allow for min power.
Does this align with what you’re seeing?
You hit the nail on the head!
Someone had changed Greyscale to Stucky.
I am looking forward to being able to assist others with what I learn here in this forum.
Thank you berainlb!
