Mintion laser cam
I have just purchased a |||60x60|Mintion Lasercam for Laser Engraver/Cutter | LightBurn Camera | Remote Monitor & Control | Positioning | Fire
camera
Its says it will control Lighburn wirelessly
Prob I have i cannot see the Lightburn Bridge on Mac os also tried on window 7 laptop same issues
Mintion Laser camera
How to i load Lightburn Bridge ?
Ip address given is wrong will not load http://192.168.42.1
I don’t think it can control LB. It should be the other way around. LB can control the laser via the camera. As far as I know, the camera itself is able to control the laser, such that LB is not required for laser control, only for gcode generation.
The Mintion Lasercam will only work with LightBurn if it’s connected via USB. It cannot be used wirelessly with LightBurn, as described in this video:
I am getting error 24 everytime i use the wireless function . Ferrite coils added to all leads . it seem to fail at same point every time
Screenshot 2024-03-10 at 11.01.06
Maybe you can reference this article to work as wireless bridge between LightBurn and Laser engraver: Mintion Lasercam wirelessly connect lightburn
May I know what laser engraver are you using?
Falcon 2 22w
