I created an award to make on acrylic, so after I had it created I needed to mirror it so I could engrave it on the back of the acrylic (I have made lots of these in the past)
Now when I mirror the award the text is not mirroring correctly, I suspect it has something to do with the text being curved to a path.
Known, and simply a function of how “on a path” works. We could probably make it work, but it would break everything that already exists if we did. If you convert the text to a path first, then it can be flipped, or the simpler alternative is to just use the new bend option, which doesn’t have the flip problem.
