When I mirrored a text to a framed circle and then applied
path to text, LB unmirrored it
Please show us screen shots of your workspace and the preview - so we can see what the problem is.
Continuing the discussion from Mirrored image and apply path to text:
Bernard, how did you create the circle
by using the blue dot?
I just used the circle tool and placed it on the T2 layer. Then I used the text to line tool, converted text to shape and mirrored it.
what is text to shape?
ok, i used the circle too, created my text. highlighted both. then did apply path to text, When it completed it it had reversed the text. Not like your example
what version of LB are you using?
I’m using 2.0.05
I don’t know what I was doing wrong but i got it to work. thanks for your help
ups… It’s late here in Denmark, it’s of course text to path, which you also correctly mention/use ![]()
… same here, sorry, it is “convert to path”
After converting to path, I group the “text” - shape and mirror it.
..no blue dot used here
2.1.00 RC2
