Im having issues with the start and end point of cuts (in this case its simple circles that were created in lightburn) not lining up. there is a distinct and obvious step between the start and end points. Using a Sculpfun S30 Ultra 33W. Has anyone else had the same issue or can help? thanks
Check this:
Your symptom is subtle, so your cause will also be subtle.
Focus on mechanical, specifically the set (grub) screws. Even slightly loose is too loose.
Thanks. I will definitely give the whole machine a once over and check everything
Here is another guide that might help with mechanical issues: Guide to mechanical adjustments and maintenance
