The first picture is what I am trying to print. The cutter does what you see in the second picture. Also, it is printing the weird parts out of order, for instance it will print from the very bottom up with the errors, as opposed to going in the expected printing order while just printing the errors in the wrong spot. That leads me to believe it is a software issue and not a hardware issue. If it were a hardware issue, it would print up to the error section, then print the error section in the wrong place.
It has the same problem with other cuts too, and on other locations on the printing bed.
I am using an Omtech 60W laser cutter with a Ruida controller, and the latest edition of Lightburn (1.0.02). The speed is less than 300 for all the cuts. Does anyone know what the problem might be?
@Ashkan4818 Yeah it’s similar. Yours seems to have moved in a curve and mine is more gradual but it’s similar. What was the issue for yours? How did you fix it?
@Ashkan4818 Doesn’t really help me on this issue, though I appreciate the assistance.
I don’t think it’s a motor issue. The reason is that it will print this part first:
