After using LB for months, today on startup, it was like the initial install - ie no machine and it was asking to plug it in and try to identify the type (which it did).
Cut library was not loaded - easy fix.
But what happened to my machine settings? - Do I have to re calibrate etc ?
Machine settings are stored on your device so unlikely you’ll need to change anything there.
how do I reload my machine/device settings from yesterday?
Did you save off a specific version of the machine settings from yesterday that you’re trying to restore? If so, go to Edit->Machine Settings then load the settings there and write them to the controller.
If you’re referring to just have the same machine settings that were on the machine previously then you shouldn’t have to do anything as the settings won’t have changed from LightBurn forgetting its own device configuration.
