Mk2 not responding after adding gavo update
Lightburn shows laser is ready but doesn’t respond. I had to install the laser manually because it doesn’t see the laser automatically . The gavo fiber works fine,any help appreciated. My old laptop without gavo license operates fine.
Was the Roly Mk2 working fine prior to the galvo update?
Upgrading your license to unlock galvo support should not affect your existing GRBL device, having additional devices connected to your PC may affect the connection, for example the COM port numbers may change so check the dropdown list in the Laser window for the port connection and try a different port.
I will give that a try tomorrow but I do believe it shows the correct ports for both lasers
Thanks and have a great night
I forgot to mention that I am using a new laptop with the gavo update. The prior laptop does still recognize and operates the MK2 fine without gavo.
