Hello
I have a mks dlc32 v2.1 control card. I couldn’t figure out which GRBL version is loaded on it. How can I see it? Or how can I load the latest version, I think 1.1f. I would be glad if you could help me.
I’m not at my machine to verify, but I believe $I will get you that info.
There are so many options, it’s nearly impossible to tell. But you can flash a new one any time, then you know it ![]()
But usually, all of them use grbl 1.1f as the grbl version, so if you go on from that, you should be fine in 99% of all cases.
Do the lines related to 1.1h that I marked represent the grbl version? Also, which of the GRBLs in the other picture should I choose?
Yes. Use just plain GRBL.
It shows version 2.3 of the MKS firmware. That should be the latest firmware version using grbl 1.1f.
Thank you very much.
