Hi all,i have MKS DLC32 V2.1 and have a problem with fire.
I have same power also 20%pwm and 100% pwm.
Whit this configuration,the tube fire automatically without wire IN (amperometer 12mA)
Besides a common ground, there are only two control signals to the lps. That is laser enable (usually the L terminal, where low is active) and the pwm power control signal (IN).
I tried to look up your laser, the best I could come up with is this one⦠Is this the one you own? This one looks like it has a Ruida controllerā¦
If you have K40 type with a āpotā control for power, the pot wiper is usually wired to IN with one side to 5V and the other side of the pot to ground. The PWM would go to H on the lpsā¦
is not a k40 but 50w voiern and the 2° photo itās my psu on my machine.
for this:āThe meter on your ādashā that you dial up the power, should be going to the IN terminal and the PWM output should go to the H terminal.ā you mean, S->IN,TTL->TH?
You have to have a common ground to send signals⦠The MKS only has ground and the PWM output going to H. The IN terminal comes from the dc voltage indicated on the console.
What wire went to the IN terminal before you upgraded the controllerā¦? Iād suggest you put it back.
This is the connections to an LED laser from your board.
There is only one connection to the mks board to the lps⦠You keep adding themā¦
The G and V outputs have no use for you here, if the system is grounded then only the S signal is used.
You photo 2 is wrong⦠You have ground from the MKS to the L input⦠This is the laser enable, so it will fire whenever the IN terminal goes high.
The connector you reference is labeled S-TTL-V ⦠it is a ttl output (0 - 5V) The pins on the connector are actually S-G-V ⦠the TTL reference you use isnāt there ā¦
Some of these you need to answer my questions, or I canāt help you any further.
What wire was going to the IN terminal before you changed controllers?
The IN output of that board goes to the IN terminal of the lps and the S output goes to the H input of the lps⦠Those are just how to hook it up to the lpsā¦
