HI
can someone help me with the wiring MKS DLC32 V2.1 TO CLOUDRAY M40 PSU, i have tried different options but my attempts failed,
My machine works with the same board, maybe i can help.
Can you be more specific about your difficulties?
My machine doesn’t have a tube like yours.
I don’t know if the tube should be connected by “TTL” or “PWM”. Each type of connection has its own port.
I leave a link to the MKS board manual where the various connection methods are described.
Connection info of cloudray:
From what I could see in the photos:
If the colors comply with the rules, the power cable (230v) has the connection changed. I don’t know if changing the neutral (blue) to the line (brown) affects anything.
- Check if the “FG” (Ground) is connected to the laser machine housing.
I feel a little lost because besides not working with a machine like that, there is little information.
