Hello, I recently finished my laser, designed by myself, using a MKS DLC32 as a controller, the laser module is a 10W lasertree, my problem is that when I command to do anything from Lightburn, the result is not as expected, I have done some You test with LaserGRBL and it does the engravings correctly as well as the cuts, I give a simple example, in laser GRBL when I command to engrave a circle it does it correctly, on the other hand in LightBurn the result is similar to what I show in the image.
Thanks in advence.
Please provide a screenshot of the design and a photo fo the resulting burn.
I think it’s likely that this post applies to your situation:
Ok, thanks i have been downloaded from the oficial site, and i´m now in the trial period.
