MM Missing Tool Length Code
I went to run the Tool Length Wizard but nothing would happen. It acts like there is missing code. I recorded all of the steps below. Step 6 does not have code in the white box. Step 7 inserts a black bock, but nothing happens. My machine never moves. It is connected because I can job it and was playing with some test material.
Step 1: (‎1/‎10/‎2026 3:45:07 PM) User left click on “CNC Tools (menu item)” in “Base1 - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 1 screenshot.Step 1 screenshot.
Previous Next
Step 2: (‎1/‎10/‎2026 3:45:11 PM) User left click on “Probing Wizard (menu item)” in “MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 2 screenshot.Step 2 screenshot.
Previous Next
Step 3: (‎1/‎10/‎2026 3:45:14 PM) User left click on “Tool Length Probe (check box)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 3 screenshot.Step 3 screenshot.
Previous Next
Step 4: (‎1/‎10/‎2026 3:45:17 PM) User mouse drag start on “Probing Wizard (window)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 4 screenshot.Step 4 screenshot.
Previous Next
Step 5: (‎1/‎10/‎2026 3:45:17 PM) User mouse drag end on “Probing Wizard (window)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 5 screenshot.Step 5 screenshot.
Previous Next
Step 6: (‎1/‎10/‎2026 3:45:20 PM) User left click on “Execute Tool Length Probe (button)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 6 screenshot.Step 6 screenshot.
Previous Next
Step 7: (‎1/‎10/‎2026 3:45:28 PM) User left click in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 7 screenshot.Step 7 screenshot.
Previous Next
Step 8: (‎1/‎10/‎2026 3:45:31 PM) User left click in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7 (Not Responding)”
Step 8 screenshot.Step 8 screenshot.
Previous Next
Step 9: (‎1/‎10/‎2026 3:47:33 PM) User left click on “Base1 (window)” in “Base1 - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 9 screenshot.Step 9 screenshot.
Previous Next
Step 10: (‎1/‎10/‎2026 3:47:36 PM) User left click on “OK (button)” in “Tool Length Probe failed - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 10 screenshot.Step 10 screenshot.
Previous Next
Step 11: (‎1/‎10/‎2026 3:47:40 PM) User left click on “Finish (button)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 11 screenshot.Step 11 screenshot.
Previous Next
Step 12: (‎1/‎10/‎2026 3:47:47 PM) User left click on “Steps Recorder - Recording Now (list item)”
Step 12 screenshot.Step 12 screenshot.
Return to top of page…
Additional Details
The following section contains the additional details that were recorded.
These details help accurately identify the programs and UI you used in this recording.
This section may contain text that is internal to programs that only very advanced users or programmers may understand.
Please review these details to ensure that they do not contain any information that you would not like others to see.
*Recording Session: ‎1/‎10/‎2026 3:45:03 PM - 3:47:48 PM
Recorded Steps: 12, Missed Steps: 0, Other Errors: 0
Operating System: 19041.1.amd64fre.vb_release.191206-1406 10.0.0.0.2.101
Step 1: User left click on “CNC Tools (menu item)” in “Base1 - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Program: MILLMAGE.EXE, MILLMAGE.EXE
UI Elements: CNC Tools, QAction, QMenuBar, Base1, MainWindow
Step 2: User left click on “Probing Wizard (menu item)” in “MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
UI Elements: Probing Wizard, QAction, QMenu, CNC Tools, QAction, QMenuBar, Base1, MainWindow
Step 3: User left click on “Tool Length Probe (check box)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
UI Elements: Tool Length Probe, QToolButton, CNCProbeWizardSelectProbe, CNCProbeWizardWidget, Probing Wizard, CNCProbeWizardDialog, Base1, MainWindow
Step 4: User mouse drag start on “Probing Wizard (window)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
UI Elements: QTextEdit, CNCProbeWizardExecute, CNCProbeWizardWidget, Probing Wizard, CNCProbeWizardDialog, Base1, MainWindow
Step 5: User mouse drag end on “Probing Wizard (window)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Step 6: User left click on “Execute Tool Length Probe (button)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
UI Elements: Execute Tool Length Probe, QPushButton, CNCProbeWizardExecute, CNCProbeWizardWidget, Probing Wizard, CNCProbeWizardDialog, Base1, MainWindow
Step 7: User left click in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
Program:
UI Elements:
Step 8: User left click in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7 (Not Responding)”
Program:
UI Elements:
Step 9: User left click on “Base1 (window)” in “Base1 - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
UI Elements: EditWindow, QWidget, Base1, MainWindow
Step 10: User left click on “OK (button)” in “Tool Length Probe failed - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
UI Elements: OK, QPushButton, QDialogButtonBox, Tool Length Probe failed, QMessageBox, Base1, MainWindow
Step 11: User left click on “Finish (button)” in “Probing Wizard - MillMage Pro 0.8.00-RC-13 @ c84582b Qt6.5.7”
UI Elements: Finish, QPushButton, CNCProbeWizardWidget, Probing Wizard, CNCProbeWizardDialog, Base1, MainWindow
got it working. I went through the Manage Probe Configuration first. Here is what it looks like.
New issue: I have material Zero point set at TOP. When running the Tool Length Probe, the head runs all the way to the top so, z=0 is all the way up. Then it cycles downward until it touches the plate. I had to set Search Z to a huge number so it would not cycle out. Why is it running all the way up?
When you Home the machine, Zzero is set when it finds the upper limit switch. This is a machine design thing.
I use a mechanical method to set the tool length, so I am not helpful on why you have to set a large “Search Z” value.
I expect it is going to a known safe position to start the cycle.
what do youy mean huge , what is the length of your Z axis mine is set at 110 mm my Z axis is 100mm of travel
if you go into device setting custom g code and scroll down to tool probe ,it will show you the code
Z generally always homes so that when a tool change is done it will always start at same height , if not homed it wont start at correct depth
…when the Tool Length Offset is applied.
My Z travel is 120mm. Now I understand the philosophy behind traveling all the way up during tool change. Thank you for explaining that. I had to set my travel distance to 100 because it was default to something like 10mm and would trigger the search error. Thanks everyone for helping.
