Modifying a DXF file in Lightburn
I was going to burn a simple .DXF shape in LightBurn. I needed to add a couple of radius that got missed, and they won’t take in the shape.
I thought if I could add them in (the lazy way), I wouldn’t have to go back and redo the dxf file (the proper thing to do).
Pat
You’ll need to elaborate on what this means? Once imported, all shapes in LightBurn should behave the same way irrespective of source.
Which is to say, once the DXF lines are imported you should be able to use the fillet tool to do the rounding without issue - let us know if it doesn’t work as expected.
When I remembered to use ‘Autojoin’ - because it it just a bunch of line - then it worked fine!
‘If all else fails - read the directions’
Patrick
All hail the users that read our documentation :pray:
