Buenos días.
Sabrían decirme que módulo láser es compatible con la Atomstack A5 V2?.
Gracias.
I believe it´s a 6w module.
If you want to upgrade Laser optical power you have to upgrade your power supply.
Till 10w there are 12V modules but you need a Power supply with more Amps.
If >10w you have to upgrade to a 24V PS.
If your controller only support 12V, or if 24V and can´t stand the needed Amps you have to put between in an adapter board.
Example:
Me refiero a poner la misma potencia, solo cambiarlo por otro de igual potencia, no encuentro la misma marca.
Gracias
