Hi, I’m using a Monport GM 60W Pro Integrated MOPA Fiber Laser (MP-UK1943) with LightBurn Pro 2.1.04 on macOS.
LightBurn detects the machine as BSLFiber and the Laser panel shows Ready. I rebuilt the device from scratch and imported the supplied BslCAD.cfg from the SeaCAD configuration folder.
The field is set to 175 × 175 mm. The red guide dot works and can be turned on from LightBurn.
The problem is Live Framing. I click Frame → Bounds → Run Continuously → Start. LightBurn behaves as though framing is running, but the red dot stays completely stationary and does not trace the design at all.
I have tested small artwork and a roughly 100 × 100 mm design with the same result.
Current relevant settings:
- BSLFiber
- Fiber Type: JPT
- Q-Pulse Width enabled
- Red Dot: IO 3
- Ready Light: IO 3
- Start Framing: None
- Start Marking: None
- Red Dot Always On: Off
- Enable Blanking: Off
- Frame Speed: 7000 mm/s
The machine remains connected and shows Ready.
Can anyone advise what could cause Live Framing to run without any galvo/red-dot movement? I can attach screenshots of my Galvo and Ports/Laser settings.
