What does this switch do?
No tool tip. No documentation. Nothing in the forum.
@LightBurn - can I get an answer, please?
What switch?
I thought that was for relative or absolute moves … I’ve never used it…
Someone will drop in and advise us on it’s function…
Correct, it’s not mentioned in the ‘move’ window documentation…
Nor is there even a tool tip…
I moves from machine zero instead of from the current position of the laser. If you enable that, when you click an arrow, it moves ‘Distance’ mm along that axis from the origin, instead of from wherever the laser is.
It’s mostly a hold-over from Ruida’s RDWorks interface functions. I added it thinking it was something people would use, but I doubt anyone does.
Good thought, I’ve never used it…
Some of this is that you figure out what works … many times you want to ‘run’ something not try to ‘fix’ what’s working…
Kind of like when you’re looking for something… you quit looking when you find it…
It was as I suspected relative or absolute …
Should we expect it to ‘go away’?
