Move function does not correpond to inch or mm settings
Using a Ruida controller–when I want move the laser head while set in the mm settings, it will move a half inch. I have to click the setting button to in then back to mm to get it to work correctly.
Please share how you determined this. What is the process you used to find this observation?
When I set up a project, send it to the laser, then I want to move the laser head to get it to my start point. I have the settings on mm and the move function is .5 mm but the laser head moves .5 inch. I have to change the settings to inch then back to mm to get the laser to function correctly. This started with the new update.
