Hello,
I just started testing the software and like it and think of buying it.
But now I’m trying to use it directly with my GRBL-Controller and it does not work as expected.
I use a GRBL_V1.1-Setup which works perfectly with LaserGRBL and UGS.
There are many issues with Lightburn which are kind of difficult to describe.
A simple example:
- I do Homing
- I move to my user zero position
- I press “Set origin”
- I press “Go to origin”
- It moves to somewhere else… I would expect, that it does not move anywhere as I just set the origin
When I just save the gcode and run it with the two mentioned programs everything works fine. I even compiled a positive-GRBL-Version as I thought it would solve the problem, but it does not.
Another problem is that when I stop a program and restart it. Lightburn moves my gantry to somewhere else but not the zeropoint.
Print and cut does not work either… Maybe these problems are related to the first mentioned.
The console output of the above written actions (first mentioned problem) are:
Waiting for connection…
Grbl 1.1hdm [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
ok
[MSG:Caution: Unlocked]
ok
[VER:1.1hdm.20210315:]
[OPT:VZ,15,128]
Target buffer size found
ok
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
<Idle|MPos:0.000,19.998,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:0.000,40.001,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:0.000,59.999,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:0.000,80.001,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:0.000,100.000,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:0.000,119.999,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:19.998,119.999,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:40.001,119.999,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:59.999,119.999,0.000|FS:0,0|WCO:53.793,67.113,-9.469>
ok
ok
<Idle|MPos:59.999,119.999,0.000|FS:0,0|Ov:100,100,100>
ok
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:01
Kind regards,
Dan
