Move Window Distance doesn't convert units
The ability to change the unit of measure in operation is handy, and every other place changing between “mm” and “inch” updates the UI, converting the increments accordingly.
The value for Distance in the Move window does not however.
If I have the Move Distance set to 10mm, then switch to Inches and forget to switch back, the laser will try to jog 10 inches. It updates the unit of measure label in the UI, but not the value.
I assume this is an oversight as I can’t see why the Move window would be the only place the values aren’t updated when changing unit of measure.
Bug has been found and will be corrected in the next patch release. Thanks for letting us know!
