Spencerv
(Spencer V)
April 23, 2021, 6:54pm
1
Hi I’m a newbie here, does anyone know how to get rid of the lines the laser uses when it moves between cuts. These lines are red in the preview mode.
Rick
(Technical Evangelist)
April 23, 2021, 7:24pm
2
Welcome! We get asked this a bunch. Here is the FAQ for this subject. Our search , found at the top-right of every page on this forum, can help you quickly find answers to many of the most common issues folks may have. Good tool to help you get the fastest possible responses.
If you have a GRBL device, and your laser is still on when moving between shapes, like this:
[image]
It most likely means you are using GRBL 1.1f or later, but do not have the controller in Laser Mode. Fix this by typing $32=1 in the console and pressing enter
If you have a Ruida or other DSP controller and are seeing this happen, it is most likely a dying high-voltage power supply unit (PSU). The drive circuit that turns the laser power off and on tends to go first, before the part that co…
system
(system)
Closed
May 23, 2021, 7:25pm
3
