Moving along the axis but the laser isn't firing
I have an 1000mm X 1000mm X-Carve with the X Controller my firmware is GRBL 1.1g I’m currently using the PLH3D 6w opt laser upon set up in the easel program I was able to test fire the laser and even successfully burned many images for a little bit under a week I started a project and just fine but when I went back the following day to add to it the X and y axis where moving but the laser wouldn’t fire if I hold do the pulse button on the lasers controller it fires but if I try to test fire in the easel or lightburn program in the console setting I get an ok command but no laser I’m so lost please help me
Maybe check the firmware settings again. We have reason to believe that the version of GRBL that ships with some XCarve units resets itself to “factory settings” instead of retaining the state like other versions of GRBL. If this is the case, you’d need to re-run the “set for laser” macro when you reset it.
I went into the console setting on the lightburn program and edited a macro for laser setup and still nothing
