Moving Home location
My home position is in the upper left corner Can i change it to the lower left?
Thank you
Assuming the machine has home switches and they’re in the upper left corner, then you must:
IMO: Unless you have a very specific and overwhelmingly powerful reason, do not mess with machine homing.
Home position is for machines with endstop/home sensors where these are located. But often you can decide where you want the laser head to stop after work is done and it can easily be in the corner you want. But, in order to “find itself” the machine with the mentioned contacts will and must drive home for each start of the machine - to position itself in the given coordinate system.
So the most practical thing will be to “accept” the correct home position, it makes construction/design easier - in my understanding.
Thank you for your response. I will take your advice and not change a thing as I am new to this..
Thank you I will leave it alone.
