I design my Lightburn projects on a MAC and then I sneaker net them to a Win 11 machine for cutting. Everything transfers fine except the cutting speed is always wrong. The number of passes and the power setting is correct but not the speed.
Weird huh?
This might mean on ONE of your computers you have lightburn set to mm/sec and other mm/min?
Check in Edit → SEttings of both
Make sure the LightBurn settings match:
You were exactly right. Thank you, I will change it
