Moving the machine issue
Im finding that when I use the move buttons it tells me its out of range even when its gone in on direction it won’t go back
You appear to have a coordinate setup issue. With your machine listed as “Own”, it is impossible to give setup advice. We have no idea how your setup is designed mechanically. You need to provide a lot more information.
In the meantime, this link will help explain coordinating systems, Homing, and Origin.
Welcome @JohnSAx, and thank you for reaching out. This is posted in the ‘Genmitsu 3018’ section with a ‘3018’ tag, so I will assume you are working with this unit. :slight_smile:
I agree with @MikeyH,
Here are our documents to help with the configuration of your CNC.
