Moving to lightburn, shapes not connecting
I’m looking to move over to lightburn, unfortunately I’m having issues with simple shapes not connecting for cuts. fill/scan seems to be working. Running a 100 watt CO2 with a RUIDA RDC6445G(EC) controller. When using RDWORKs I don’t have the same issue. Both pictures are under magnification and around 8-10mm Any help on what needs to be adjusted is much appreciated! pictured attached!
What is your “Min Power” set to in your settings? Min Power is what’s used in corners. I’d say that you need to bump it up close to what your Max Power is set to.
goodness, can’t believe I missed that. thank you!
