MSG: 3: Warning: Caution: Unlocked
My cutting halts midway, and the above warning appears. Can someone please help.
I have an Ortur Laser Master 3.
Thank you
Hi Nisha,
Could you scroll a bit higher in the console window and copy/paste the full output when machine errors out?
Also, if you were to unplug the laser head cable, and run the same project, does it still error, or does it finish all motions without errors?
Hi!
Sorry I’m very new to this so I’m not sure how far up I need to start. This probable shows I’ve done several attempts and it keeps jolting.
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:211]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230417]
[SN:40D3E6D7EA28944CAEF17B21D01AE15C]
[VER:1.1f.20220325:]
[OPT:VNZHS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:70:04:1D:FA:18:AC]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:24801,16|H:1,7>
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:24801,13|A:SFM|H:1,7>
ok
Starting stream
Stream completed in 0:18
Starting stream
Layer C00 Pass 1 of 2
Layer C00 Pass 2 of 2
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
Job halted
Stream completed in 1:04
[MSG:Reset to continue]
ok
Ortur Laser Master 3 Ready!
OLF:211.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:3:Warning: Caution: Unlocked]
This is peculiar.
Could you show a fullscreenshot of your LightBurn screen.
Seems you are getting very close to the edge and the controller is getting confused and thinks is going to hit the rails.
If you move the object 1mm in and up does it still happen?
So last time I tried to do a cut this is what showed mid cut
ALARM:2
On or near line 0:
Job halted
but today its the MSG 3 that’s coming up
Settings screenshot. Maybe this will shed some light
I believe you did not tell firmware you extended the machine
Type in console $131=850
Press enter
Retry
Omg it worked! Thank you so much!! Do I have to key this in everytime? or is there a setting I need to update?
Once set in firmware is forever.
Exception is:
a) if you reset firmware
b) do a firmware update
Brilliant :slight_smile:
