[MSG:Angle not calibrated]
Hello I have a Gluwphy engraver, and I frequently get this message - at what feels like - random times.
Gluwphy GM1 1.2h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
I haven’t seen other posts that refer to the “angle” not being calibrated.
Here is a screenshot of the machine stopping on a random layer with that alarm.
I am worried that there is something wrong with the laser. Thank you in advance
I’m not familiar with your particular machine. Does it have a feature where either the base or possibly the laser head can be oriented at a different angle?
In any case, note that the message you’re getting is an informative message, not an error. This should not be preventing you from proceeding as expected.
I see you have a separate ALARM:8. Are you possibly dealing with a separate issue when homing?
Your initial comment prompted me to check the manual and it has instructions on “How to set Red Cross Offset to Laser” - which has likely solved the issue.
As far as the alarm, that one was my fault, fumbling with the starting position and origin.
Cheers!
