[MSG:3:Warning: Caution: Unlocked]
I’m a newbie; (ortur lm3) receiving for laserburn grbl error code at beginning of job, text works, but test project (lion heads various spd/pwr settings) stops with the following msg…
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
[MSG:‘$H’|‘$X’ to unlock]
$X
Didn’t touch anything after initially starting the project, but received the stop error code, I try doing as you suggested.
Research had indicated either entering in the cmd line $131=850 or/both $RST=* ??
The complete error msg was;
Ortur Laser Master 3 Ready!
OLF:211.
OLM:GENERAL.
$X
These are only status messages, there is no error.
Solved: Turned OFF all Layers, then turned each one back on testing each time… After doing this NO reoccurring errors.
