Multi copy cutting
Can i cut multiple copies of the same
image and set the cut so that it runs across the bed doing say ten at a time rather than just burning each image seperetly?
Optimisation settings allow you to do pretty much anything, but you may find that doing full-width scanning is way slower than ‘fill individually’ and is very dependent on what you are engraving.
Same objects, same speed/power, both using ‘fill all at once’
When set to ‘fill individually’, little difference from the first one where the objects are together.
