Hello all forum members
When I have a window open and connected to the laser and working.
Why don’t I get one
connection with to the laser from the second or third or fourth window . I have to close the first window to regain connection with the laser again
I would like to change
between the windows for burning without
restart LB
Kristian
The laser can only have one connection at a time. You need to disconnect in one window before connecting in another window. You can create a dummy machine to connect to, disconnecting from the current laser. In the laser panel, click devices, create manually, No Machine nd follow the prompts. This will allow you to select “No Machine” in the current Lightburn window, disconnecting from your laser. Then you can connect in the other window.
Thx Tim
I`ll try that tomorrow
