Hi I am new to lightburn, slowly learning how to use it. I made a template I wanted my laser to cut out, I copied and pasted it 3 times to have multiple. Program is set for 1 pass on each however it will cut over the same image multiple times causing the wood to burn. What setting am I not doing right.
If I do them 1 at a time it will work fine and make only 1 pass. Any help would be appreciated
More than likely when you copied them you left multiple stacked copies
So the program is running what you intended,
best way to find out is to offset them or move each copy to a different layer (which can come handy later on for isolation)
