How do i add multiple cuts.
would like to cut stencil,
would like to cut the inside details first then cut the outline border shape, so that the piece is not loose when cutting inside details
Order is determined by order in the cut list. Top ones get cut first. Then I think within a certain color, it cuts inside to outside order. You can manually override this with using different colors and putting them in the order you want.
awesome will give it a go thank you very much for assistance
Henk, there is also an option located in the Optimization Settings named “Cut Inner Pieces First”. Check that out, I think it may be what you are looking for
The default is as Blake says, but you can change that easily. Watch here for how to change the cutting order:
