Hi I want the out object be cut like the inner objects, can some one help?
i dont want it to cut back and forward in one littel space.
Hello Adam
Could you provide some visual helpers so we can understand what you are refering to
And/Or post your LBRN file
i believe the issue is your outer object is “broken” apart in 2
You need to select them and join then (Auto Join Alt+J) but depends on how they are constructed
Also to auto join the parts must be touching eachother perfectly
Yes , it worked , i ungruppet dem and then marked the alt+j.
thank you .
Great news!
