Multiple engrave pieces are off center
Omtech 60W/50W CO2 laser with Mac M1mini LightBurn version 2.0.04.
I set up a jig with multiple same objects to engrave. Everything okay on first object, remainder of five of same engrave has “jogged” about 1 1/2mm to the right in each one. I have done multiples many times without this little problem. What did I screw up?
Did you make any changes since you replaced that limit switch ?
Is that a jig made from before you did the swap ?
Jig made before but I modified slightly and saved after installing new switch. Haven’t run again to see if it is corrected
Will let you know. Thanks
