Having fun with the Text to a Path feature, however I haven’t figured out how to add the 1st line to the top of a circle then add a second line of text to the bottom of the same circle.
Thanks guys, doing a great job!
You can’t, at least not the way you are thinking. LightBurn provides ‘Apply Path to Text’ allowing you to apply a single text object to a single path. You will need to break the circle into 2 paths or create a second circle to use for your second text object.
Thank you Rick, I appreciate your help.
