MUNBYN ILEM-GR 20 w laser will not connect be found
Lightburn can not find my MUNBYN ILEM-GR laser on my Mac mini.
The ‘add’ says it will run Lighburn. That would leave your mac.
From the command window you should be able to type ‘lsusb’ and get a listing of all usb connected devices you have are privileged enough to be able to read.
What did you try and what results are you getting from Lightburn and from the ‘lsusb’ query.
after typing lsusb I get: zsh: command not found: lsusb
I’m not familure with Mac’s, I use Ubuntu Linux… I googled it and found this thread… I guess you need to install it…
Try this link…
