Hi all,
I’m a true newbie to laser engravers/cutters and the respective software. I decided to start with an Elegoo Phecda 20w machine and also purchased Lightburn. I’m the sort of person that will beat my head against the wall until I figure something out but I also recognize when I need some help. So here goes.
As mentioned, I have the Elgoo 20w Phecda and I’m attempting to cut 1/4" Polystyrene foam. I did some research before attempting this and found many recommendations before trying it because I wanted to make sure it was even possible. So I ordered the 1/4" Polystyrene sheets (11x17) and have tried many different settings. The recommendations I kept finding were in the neighborhood of 6mm/s and 20% power. Well, that doesn’t even make a mark on this stuff. After attempting a wide range of settings, I thought maybe it was something with the focal length. This laser has a positioning bar that flips down to help adjust it to the proper distance and set the focal length. I’ve done that as I understand it to work but the best I can get between trying that and various settings is a couple of melted holes (from repeated attempts) and some very light surface etching.
So I thought I’d reach out and see if anyone had any recommendations?
Thanks in advance!
